Slot.it Scp Negative Controller Woes
shadow_rusty
Recently tried to get my Slot.It controller to work on a friends negative wired track...
Plugged in my negative module, connected to the track, and dead shorted the power supply...
Checked wiring, Black to track, Red to Posative / Track, Yellow to Negative.
Yep, all looked ok. As it all seemed correct, I assumed that the module was stuffed.
Had to race that night with multiple annoying Parma's... (Just never have liked them)
Got home, and I remembered that I had used it on my standard scaley sport track before with an adaptor.
Looked everywhere, but apparently I'd left the adaptor it at my fathers.
None the less, I was determined to figure it out.
I pulled the module off, seperate the board from the shell, and thought to myself, I'll remove the jumper which shorts the track during power off and retest.
Still not working, but it was no longer shorting out the power supply.
I then looked at it a little closer, and noticed that the solder point marked '+' had the yellow wire soldered to it, and the solder point marked '-' had the red wire soldered to it.
So, I then swapped over my testing leads, and hey presto, everything worked.
So then, it was off to the net to find out why I had it wrong...
I figured that I must of messed up the wiring for negative tracks in my head, but no, I had it right, and slot.it had it wrong, well sort of...
Turns out that while Slot.It have it correct here
http://www.slot.it/D...ritySCP1.en.pdf
They have Yellow and Red quoted incorrectly here (page 4)
http://www.slot.it/D...uale-UK-1.1.pdf
The colour scheme of the SCP-1 cables follows the standard US (Parma) colour coding. In
our opinion, it does not make sense to use anything other than red for battery power and anything
other than black for ground, however since the long time standard established convention is
different, we decided, reluctantly, to follow it.
So: WHITE is +, RED is – (ground), BLACK is motor (track). If you have a DS connection box,
colour will match the existing colours on the female plugs of the box.
Anyway: plug the WHITE/YELLOW cable into the POSITIVE (+) terminal of your track; plug the
RED cable into the NEGATIVE (-) terminal of your track; plug the BLACK terminal to the motor
connector of your track, then go to the Quickstart common section chapter.
Whilst that statement is true for Posative polarity tracks, it appears that they failed to notice that on a negative polarity track, Red is posative, not Negative.
So, long story short, if you are having issues with a negative module, check that your module is soldered correctly with the correct colour scheme...
I've now swapped them on the module so I don't get caught out again...
Edited by shadow_rusty
    No members to show
  • Member Statistics
    • Total Members
      4,958
    • Most Online
      4,780
    Newest Member
    NoShelfQueens
    Joined
