Track Routing
aquakiwi
only thing I know is make sure the collet can accept the smaller router bits - the 1/8 or 3.2mm bits have a smaller diameter shaft than standard bits (least the ones I have bought do) I had to change the collet on dad's router to accept the smaller bit. Also an attachment for dust extraction is handy
Hi Aquakiwi,
I have the older version of this
https://www.bunnings.com.au/ryobi-400w-trim-router_p6210607
only 400 watts but did a great job.
Just make sure you get a twin flute router bit.
2025 - Mad Man Motoring (Triple M) Proxy - Group 5 - 1:32 & 1:43
https://auslot.com/forums/index.php?/topic/37451-2025-mad-man-motoring-triple-m-proxy-group-5-132-143/
__________________________________________________________________________________________________________________________________________________
Over the years I have used several routers.
The Bigger Makita is great I used two when doing my own track, borrowed from work. Both had dust extractor adapters fitted.
But when routing my rally track I used a trimmer as the base is much smaller and fitted the narrow rally track, it had plenty of power for the 1/8 bit and easy handle, just lacked good dust extraction, so I fitted a vacuum hose to it.
Here's a pic of my best friend. I would love to send it to you to use but could be starting a new project soon. How long would you need it for??
2019 NZ RTR Nationals Gt 3rd
That is the trimmer I have, Made by Makita and marketed much cheaper.
It is OK for what you are doing.
If you were going to do a big track with multiple lanes I would suggest going bigger like Branco,s.
I have an old B&D router that I use as well. But the small foot print on the trimmer is good on the narrow rally track.
One thing to consider - slot width. I saw 3mm and 1 1/8th (3.18mm) mentioned above -
Alan - if you're doing a rally track and have tight curves, maybe worth using the wider 1/9th bit, as some modern guides can struggle on those tighter bends with the narrower bit.
Also, try and get a "twin flute" bit if you can in that size, and if it is a fancier European brand - as opposed to an "evercut" or similar from M10, I gather you can get ones that spit the dust upwards and self clear the slot, so they are less likely to have a stick-and-burn
(is that correct Phil, I'm a bit rusty)
May not matter for hand routing, but I know when I used CNC machines for the modular stuff, and Oakland, the CNC shop had issues with the single flutes - 2 of them "ker-snap"
Mark, do you know a source of suitable "bits" we have only a Mitre 10 here and they don't stock them. I think I borrowed yours last time, can probably pick one up in Auck. but don't like going there.
Edited by aquakiwi
Alan, I used a Linbide brand twin flute 3.2 M4 1/8 straight cut 1/4" 6.4mm shank without any hassles on my rally loop.
Go to a power tool specialist shop and talk to them....should be under 40 dollars.
Good point on the rebating bit shaft diameter there munter.
Alan, I used Linbide brand too - couldn't remember the brand till munter said the name.
If you can't get one up there, I could grab one from Thomson's power tools here for you, and stick it in your next order.
Would you like me to check price and availability - they sometimes need to order in non-metric sizes.
Your best friend looks a bit stiff and starchy.... actually, he reminds me of Will Robinson's best friend, are they related.
[ for those under 40, we can explain]
That would be great if you could get a price thanks Mark
