Caddo Posted May 7, 2017 Report Share Posted May 7, 2017 Hi all A recent change of events in the local club racing scene has got me thinking about tyres. For years I have avoided MJK's/urethanes, and pushed for classes to run rubber tyres with shoulder/air rims. The laptime gain using rubber tyres comes at a cost though. Slot It N22's are more difficult to true, deteriorate more quickly, and are treatable with oils etc. I was an enthusiast for these rubber tyres, but have come full circle and now find myself pushing to use MJK's. Main reasons being MJK's are: Aussie made untreatable easier to true longer lasting, with wider performance window supplying a wide range of tyre profiles slightly lower traction level slows cars to more realistic speeds and forces drivers to drive well or lose time with sliding Most of our classes are 1/32 12V mag free with maximum 23000rpm motors. I am wondering how many clubs regularly use MJK's without track goo etc, the benefits observed and the reasons for adopting them initially. Cheers Caddo Quote Link to comment Share on other sites More sharing options...
kart.68 Posted May 7, 2017 Report Share Posted May 7, 2017 (edited) Hi, I race at Way2fast Canberra no goo 1/32 with MJK tyres with good results and Paul Gage are good as well. Edited May 7, 2017 by kart.68 Quote Link to comment Share on other sites More sharing options...
mattcrackers Posted May 8, 2017 Report Share Posted May 8, 2017 At WASCRG (West Australian Slot Car Racing Group) we have used MJK's for all classes except for the NSR GT's and NSR Le Mans classes which use the standard NSR tyres. We run on a 4 lane timber track painted with Ferrodore, no goo or other additives allowed. This year is the first time that the rules state that all classes must use MJK's only, no other tyres are allowed. I have noticed that the lap times have slowed a little in the NSR Le Mans class, there used to be a few of us getting in the 5.7 sec per lap but now the quickest is around 6.2 sec. The NSR cars now have to be driven a little different to before due to some loss of traction, you don't seem to be able to go as hard as you could using NSR's own tyres. Personally I would have liked to of stuck with the NSR's on the NSR cars but it's no real loss, everyone is using the same tyres so no one is disadvantaged anyway. The owner of the track, Syd, has said that by using the same type of tyre for all classes that the traction should not differ between classes as it can going from different tyre types. cheers Matt Quote Link to comment Share on other sites More sharing options...
kalbfellp Posted May 8, 2017 Report Share Posted May 8, 2017 If you are now using treated runber tyres, you may have trouble convincing the racers to change especially on the faster cars. We run eurethane on the lower powered cars, but find that they are have much less grip on the faster cars than treated rubber. Quote Phil https://www.hobartminiaturecarclub.com/ Email Link to comment Share on other sites More sharing options...
shadow_rusty Posted May 8, 2017 Report Share Posted May 8, 2017 MJK's are my go to tyre. Yes they typically have less grip than the 'correct' rubber, but as every surface type seems to have a different correct rubber, they play the averages well. Also, they are great on Scaley track where most rubber does not work well. And yes, in high torque, high rpm cars, rubber will usually be quicker. Quote Stolen from SlotsNZ Team ABC Team Leader (Ambitious, But Crap) Home Track Threads - Shadow's Semi-Permanent Layout & Another Rug Racer & Proud of It & Gymkhana Test Track Car Collection Thread - My Car Collection Charts / Diagrams - MJK Tyre Selector / Slot.it 4wd Gearing / PoliCar Rollout / Rollout Chart Generator / SCX 4wd Rollout / Track Wiring with Brake on Track Call Link to comment Share on other sites More sharing options...
Caddo Posted May 8, 2017 Author Report Share Posted May 8, 2017 At WASCRG (West Australian Slot Car Racing Group) we have used MJK's for all classes except for the NSR GT's and NSR Le Mans classes which use the standard NSR tyres.bunch of racers Pity you guys are 4000km away, good to find another like minded bunch of racers though We run on a 4 lane timber track painted with Ferrodore, no goo or other additives allowed. Should have mentioned, our tracks are gloss or satin finish, no goo either. This year is the first time that the rules state that all classes must use MJK's only, no other tyres are allowed. I have noticed that the lap times have slowed a little in the NSR Le Mans class, there used to be a few of us getting in the 5.7 sec per lap but now the quickest is around 6.2 sec. The NSR cars now have to be driven a little different to before due to some loss of traction, you don't seem to be able to go as hard as you could using NSR's own tyres. Personally I would have liked to of stuck with the NSR's on the NSR cars but it's no real loss, everyone is using the same tyres so no one is disadvantaged anyway. Good point, lap times are only relative to other racers The owner of the track, Syd, has said that by using the same type of tyre for all classes that the traction should not differ between classes as it can going from different tyre types. KISS, not the band, the simplicity. We have also found mixing urethane with rubber tyres can result in varying grip levels from heat to heat. cheers Matt If you are now using treated runber tyres, you may have trouble convincing the racers to change especially on the faster cars. We run eurethane on the lower powered cars, but find that they are have much less grip on the faster cars than treated rubber Copy that Phil, it's like asking them to cut off a limb! I've done scale calcs based on lap times on my small 16m track, and we are doing 410km/hr scale speeds with GT3 cars on rubber tyres. MJK's bring this down to 330km/hr, a little more realistic, with the added bonus you can catch a glimpse of the car as it passes by. Also makes for longer racing battles with fewer offs. MJK's are my go to tyre. Yes they typically have less grip than the 'correct' rubber, but as every surface type seems to have a different correct rubber, they play the averages well. Great point SR, they also stay consistent from meet to meet with little change in performance. Maybe need a light sand and off they go again. Also, they are great on Scaley track where most rubber does not work well. And yes, in high torque, high rpm cars, rubber will usually be quicker.As Matt mentioned, if all are on MJK, does it really matter? Hi, I race at Way2fast Canberra no goo 1/32 with MJK tyres with good results and Paul Gage are good as well. Thanks Kart, what is the track surface? Happy to stay with MJK though, made locally Quote Link to comment Share on other sites More sharing options...
difinity Posted May 8, 2017 Report Share Posted May 8, 2017 On mostly semigloss routed tracks, I run a mix of MJK, Paul Gage XPG and sometimes slot.it rubber. I find the NSR prep and truing beyond my ken for now. The urethanes seem more forgiving, with MJK better on Ferradore. (Don't know anybody who still uses that though - most of our ferradore tracks have been redone in a semigloss - improves grip, clean with a damp rag, can run any tyre incl foam if needed. The rubber tend to slide around a bit until the track is 'rubbered in'. Don't mix silicone though, and lubricants like WD40 tend to turn urethanes to mush very quickly. Quote Link to comment Share on other sites More sharing options...
ZeGas Posted May 8, 2017 Report Share Posted May 8, 2017 Grip is like for like. A rubbered up track will grip better with rubber. I have coated my track with Cabots floor clear urethane and guess what, the MJK's are just fine as are other urethanes. Rubber not as good. Quote Cheers Grant . 2025 - Mad Man Motoring (Triple M) Proxy - Group 5 - 1:32 & 1:43 https://auslot.com/forums/index.php?/topic/37451-2025-mad-man-motoring-triple-m-proxy-group-5-132-143/ __________________________________________________________________________________________________________________________________________________ If life gives you lemons, take them, free s#!t is cool. Link to comment Share on other sites More sharing options...
GAS41T Posted May 8, 2017 Report Share Posted May 8, 2017 (edited) Rubber is best on my track suede with cabots clear... But eurathane is great for restricted slow motor class cars I tried mjk on my IPS proxy car but the ninco rubber was quicker & nicer to drive consistently Rubber is my preference Rossko Edited May 8, 2017 by GAS41T Quote Link to comment Share on other sites More sharing options...
jphanna Posted May 9, 2017 Report Share Posted May 9, 2017 IN my Monday night club, we use MJK for all motors under 18K. they are fine with lower performance motors. over that in grunt, we use F22 or N22. its not much fun having a high performance motor, with MJK style tyres. just fishtailing constantly on some of the tracks. weights dont seem to help that much either. Quote Shed People Mutual Admiration Society 2 times Australian National Champion 1991-Flexicar 1999- Group 12 Sedan Link to comment Share on other sites More sharing options...
munter Posted May 9, 2017 Report Share Posted May 9, 2017 What shore rating are MJK? There are a few choices of hardness when casting tires. Quote John Warren Slotcars are my preferred reality Link to comment Share on other sites More sharing options...
Caddo Posted May 9, 2017 Author Report Share Posted May 9, 2017 Probably my last multi quote, relax I find the NSR prep and truing beyond my ken for now You and me both Difinity, life is too short! Grip is like for like. A rubbered up track will grip better with rubber. I have coated my track with Cabots floor clear urethane and guess what, the MJK's are just fine as are other urethanes. Rubber not as good. Interested if your track surface is ultra smooth, we've found the same thing on a high gloss, smooth track. Rubber starts off very quick, but as the rubber builds on the track, the lap times slow. Found urethanes much more consistent from start to finish. IN my Monday night club, we use MJK for all motors under 18K. they are fine with lower performance motors. over that in grunt, we use F22 or N22. its not much fun having a high performance motor, with MJK style tyres. just fishtailing constantly on some of the tracks. weights dont seem to help that much either That is part of the attraction of MJK for me, there is no real advantage in overpowering them. We ran a host class with Nissan R390+30K IL Shark, Audi R8+21K AW King, and Audi R8+22K AW SHark and all on MJK with air/double shoulder rims. Most of us were circulating all 3 cars within a tenth of each other. John, curious if you are using air/double shoulder rims? Rubber is best on my track suede with cabots clear.., gday Ross, satin or gloss, smooth or rough finish? I've coated my Cabot's satin clear with gloss to improve the traction for MJK's But eurathane is great for restricted slow motor class cars I tried mjk on my IPS proxy car but the ninco rubber was quicker & nicer to drive consistently Rubber is my preference Agree that generally MJK's a little slower and not quite as grippy as rubber, but have other good points rubber doesn't. Rossko What shore rating are MJK I had in my head ~40, but not 100% sure. They do feel firm, the double shoulder rims help cushion the ride abit There are a few choices of hardness when casting tires. Would be interested in having a crack at making my own, is it difficult? Any tips? Quote Link to comment Share on other sites More sharing options...
Lloyd Lucas Posted May 9, 2017 Report Share Posted May 9, 2017 Slightly on topic, slightly off. What are MJK's like on a carrera track? I've been using silicone and its ok, but some cars they just dont grip at all. Quote Link to comment Share on other sites More sharing options...
Peter Gunn Posted May 9, 2017 Report Share Posted May 9, 2017 Hi Lloyd i have a 2 lane circuit built out of Carrera track and also have experiance of racing on a 4 lane Carrera track and the MJK's are my choice of tyre on nearly all my cars , they are round to start with which helps and only need a little truing in the odd case, i have them on cars ranging from 16k to 35 k motors and really find them very good , don't forget the Carrera track is very grippy so you get a fair bit of wear with those tyres. don't recommend mixing silicone with urethane though Quote Link to comment Share on other sites More sharing options...
jphanna Posted May 9, 2017 Report Share Posted May 9, 2017 What shore rating are MJK? There are a few choices of hardness when casting tires. As far as i know we just get one shore here. it feels like 30.....i cant be sure of the shore! 1 Quote Shed People Mutual Admiration Society 2 times Australian National Champion 1991-Flexicar 1999- Group 12 Sedan Link to comment Share on other sites More sharing options...
munter Posted May 10, 2017 Report Share Posted May 10, 2017 Sure thing..... 30 should be quite a softy. I have made a few using a 40 mixture which seem to work fine. To be sure, to be sure. Quote John Warren Slotcars are my preferred reality Link to comment Share on other sites More sharing options...
kalbfellp Posted May 10, 2017 Report Share Posted May 10, 2017 John the MJK,s that I have here measure 40 shore A, do not know if that is the only harness they use. Quote Phil https://www.hobartminiaturecarclub.com/ Email Link to comment Share on other sites More sharing options...
munter Posted May 10, 2017 Report Share Posted May 10, 2017 Thanks Phil. I have used MJK before and thought they were about that. Mark Burgess experimented with softer mixtures and gave me a set(4) to try. They worked well. Quote John Warren Slotcars are my preferred reality Link to comment Share on other sites More sharing options...
kalbfellp Posted May 10, 2017 Report Share Posted May 10, 2017 I find that 30 is a bit soft for most cars on our tracks,so mix to get 35 Shore A, we only use Eurethane on a few classes and they are all high profile. Quote Phil https://www.hobartminiaturecarclub.com/ Email Link to comment Share on other sites More sharing options...
Lloyd Lucas Posted May 10, 2017 Report Share Posted May 10, 2017 Hi Lloyd i have a 2 lane circuit built out of Carrera track and also have experiance of racing on a 4 lane Carrera track and the MJK's are my choice of tyre on nearly all my cars , they are round to start with which helps and only need a little truing in the odd case, i have them on cars ranging from 16k to 35 k motors and really find them very good , don't forget the Carrera track is very grippy so you get a fair bit of wear with those tyres. don't recommend mixing silicone with urethane though Thanks Peter, when/if i change over I'll change all my tyres to mjk's. Quote Link to comment Share on other sites More sharing options...
kart.68 Posted May 10, 2017 Report Share Posted May 10, 2017 Hi, Testing today fly Lancia 037 no mag on Carrera track Paul Gauge XPG 9.57 MJK 9.39. Quote Link to comment Share on other sites More sharing options...
espsix Posted May 10, 2017 Report Share Posted May 10, 2017 (edited) We use either MJK or Ortmanns, I've found that the Ortmanns are a couple of tenths quicker over a approximately 6 second lap, but the MJK's are smoother, and don't go out of round like the Ortmanns do when the cars are not being used. ( not sitting on the rear tyres ) In 24th scale the BRM Group C wheels with MJK ( to suit ) rear tyres are unbeatable on any rubber tyre class car you can fit them on. And they're stretchy, I've see a 24th tyre with a 12 mm hole go on a 17/18 mm rim many a time, and haven't heard of any splitting. And you can always find a tyre to fit a rim. Only ever had one set of Paul gage tyres, and they're were way to big for the rim they were supposed to fit, so never bought any more. Edited May 10, 2017 by espsix Quote Link to comment Share on other sites More sharing options...
shadow_rusty Posted May 15, 2017 Report Share Posted May 15, 2017 From Paul Gauge, his XPG's are 20 shore, and PPG's are 40 shore. As MJK's are somewhere in the middle of those in terms of grip, I'd estimate that they are approximately 30 shore. 1 Quote Stolen from SlotsNZ Team ABC Team Leader (Ambitious, But Crap) Home Track Threads - Shadow's Semi-Permanent Layout & Another Rug Racer & Proud of It & Gymkhana Test Track Car Collection Thread - My Car Collection Charts / Diagrams - MJK Tyre Selector / Slot.it 4wd Gearing / PoliCar Rollout / Rollout Chart Generator / SCX 4wd Rollout / Track Wiring with Brake on Track Call Link to comment Share on other sites More sharing options...
jphanna Posted May 15, 2017 Report Share Posted May 15, 2017 John the MJK,s that I have here measure 40 shore A, do not know if that is the only harness they use. the dealer for MJK in adelaide, i only saw him thurs night.....did i ask him what SHORE he supplies? of course not....... i am under the assumption that whatever MJK classes we run, we all get the same type. i would be pissed if i got 40, and the guy next to me was running a special 'back door' batch of 25 or so!!! Quote Shed People Mutual Admiration Society 2 times Australian National Champion 1991-Flexicar 1999- Group 12 Sedan Link to comment Share on other sites More sharing options...
shadow_rusty Posted May 15, 2017 Report Share Posted May 15, 2017 (edited) I have received the WRP 'Brown' extra soft tyres in a pack off of the wall of tyres before, so it can happen. Not normal, sure, but it can happen. PS. I went back, but that was the only pack out of the batch of SCX Rally tyres that was the WRP 'Brown'... :( Edited May 15, 2017 by shadow_rusty Quote Stolen from SlotsNZ Team ABC Team Leader (Ambitious, But Crap) Home Track Threads - Shadow's Semi-Permanent Layout & Another Rug Racer & Proud of It & Gymkhana Test Track Car Collection Thread - My Car Collection Charts / Diagrams - MJK Tyre Selector / Slot.it 4wd Gearing / PoliCar Rollout / Rollout Chart Generator / SCX 4wd Rollout / Track Wiring with Brake on Track Call Link to comment Share on other sites More sharing options...
