Gear Modulus Compatibility
ZeGas
I am trying to come up with various gear ratio options but am having trouble finding the same modulus input / output gears.
Only exploring inline options only at the moment.
Have a couple of ideas.
Pinion / Crown
The crown is limited to 20T only (2mm axle) at the moment but the pinion can alter between 8T, 9T & 11T (1mm shaft)
Problem is the 20T & 8T can be 0.5M but the 9T & 11T are 0.3M.
Beveled
Second option is beveled gears offer more variety,  with output gears in the ranges of 15T, 16T & 18T all 0.5M while 20T is available in 0.3M & 0.4M. All 2mm axle.
The input gears 9T & 11T in 0.3M and an 8T in 0.5M. (all 1mm shaft).
Although the sizing don't really matter for my question it gives a bit of background.
The question is has anyone played around with the different modulus and can you get a good mesh by offsetting the gears slightly?
2025 - Mad Man Motoring (Triple M) Proxy - Group 5 - 1:32 & 1:43
https://auslot.com/forums/index.php?/topic/37451-2025-mad-man-motoring-triple-m-proxy-group-5-132-143/
__________________________________________________________________________________________________________________________________________________
Offsetting a AW or SW  spur gear is not possible, the relation of pinion height to gear height has no effect on mesh.
You can offset Contrates / Crown Gears, but you have to have a gear that is made offset like the S&K 0.5mm offset to get the best mesh.
S&K are the only manf of offset contrates, but having said that you can get the Voki contrate to run slightly offset.
Thanks, not looking at AW or SW only inline.
