What Tools And Materials...
slotbaker
I'm getting the power to the lanes working first, apparently you'd removed the wires to allow the track to work without the computers but that the timing will still work or something. I dunno - I'm just laughing and having a ball with the boys doign stuff..
I had set it up so the power only need be connected and it would go RED WIRE, BLACK WIRE.
Eno start a new thread with pic's called Get My Track Going :)
Sorry off topic.
back on topic
Eyelet's for rim repair's
Regard's
Team Phoenix
Premier Raceway Build
Gallery Raceway Build.
Heany Park Raceway Build
I explained to the missus that I'm adding some bar stools and a bar fridge to the setup before it's done.. I was in enough trouble for that.
..I haven't mentioned I need a TV & couch down there for race days yet..
Forget the bar stools and couch, it's hard enough to get marshals as it is.
Corporate greed is driving inflation.
Cash doesn't crash, use it or lose it.
  • 5 months later...
Picked up this little item today
It's primarily a trimmer, but can be used (at a pinch) as a router
Just started rebating some of the rally sections to replace the tape with braid and it's ideal for any tight sections
My First track was routed using this exact router, and did not have a problem..
Regard's
Team Phoenix
This is my second one, the first one did my original 24mtr 3 lane track + all the mods, and the first 2 rally tracks, ended up burning it out ages ago
Yep, I picked up one of these for doing my rails on the HO track; with this jig I was able o make a more accurate cut than with a bigger router:
My only beef with it is that there is no adjustable speed controller :starwars: Which was needed for routing perspex for the intended bridge ...
Richard
MCGREGOR168's correct... just went to the Big Green Warehouse and apparently GMC is no longer on their shopping list...Ryobi are now exclusive.
So I got this r-e-a-l-l-y cheap!!!! :o
Just what I need to cut those timber fences!
Dick
SCMR build thread
Woodbrook Valley build thread
  • 3 months later...
I think there was a thread on this not so long ago. Have a look through some old threads. It had some good info in there
Is that better?
i was just re -reading the whole thread and the word superglue seems to be mentioned most of the time,,,,,,,,,
it was a good buy to get the aluminium case they selling at supercheap auto
because super glue was always mentioned, i put one little tube in my box............
just when i was going to pack up to go out to race........
due to unknown reasons , my box got stuck forever .
i had to use a dremel to cut it open.
upon closer inspection, i noticed that the lid was shut tgether by superglue .
the tube seemed to sprung a leak and it flowed right through and seeped into the crevices.
carefull with those little tubes mates .
no harm done to the cars but need a few more little tools again........
probably a screw or driver must have poked a little hole in its side
  • 10 months later...
I always seem to be going to the local hardware or hobby shop every weekend to buy more tools for this hobby. There must be a point where you have enough of them and can make do
Intersted to hear what people regard as the essential tools for the sloter's toolbox? I know it depends on what part of the hobby you are into - club racing, metal chassis's, scratchbuilding, or just racing scaleys at home with mates, but there must be a set of essentail tools we all have in common. I'll list what what I think
Basis items
1. Good 3mm screwdriver set
2. Good set of allen keys
3. Long nose pliers and sidecutters
4. hobby knife
5. Pinion puller (Ninco)
6. Jeweller's files
7. Range of glues - Araldite, superglue, contact etc
8. Vernier calipers
9 Paints and brushes
10. Steel rule
11. Hobby scissors
12. Small hobby vice
13. Car setup block
14. Feeler gauges
15. Lube oil and braid conditioner with needle applicator
16. Sandpaper
Nice to have
1. Dremmel
2. Tyre truer
Cable ties,
A good light,
Air commpressor,
A powered board with a slot to test/run in motors.
Surgical blades.
More here..
Or this one for a laugh.. :P :nice:
Edited by Davnic74
Regard's
Team Phoenix
