MrFlippant Posted June 24, 2023 Report Share Posted June 24, 2023 Slot Car Winners Podium 1/32 and 1/24 versions, suitable for single, MMU, or multi-part printing Both STL files have multiple bodies. The numbers are separate bodies, so can be printed as a multicolor model (such as with the MMU, Palette, et al), or split into objects and printed seperately. If you prefer debossed numbers, you can split into parts/object and just remove the numbers, leaving only the indentation as the marking. Or, you could split it into objects and then print the numbers in whatever other color(s) you want and glue them in. If your slicer can't split STLs into their component bodies, give PrusaSlicer (or SuperSlicer, Bambu Slicer, Orca Slicer) a try. The 132 podium is a single part with the numbers as separate bodies, and should fit on most “standard” size FFF printers such as the Prusa MK3, Creality Ender 3, etc. The 124 podium is a bit large for those printers, so each level is also a separate body, held together with dovetails. If your printer is not large enough for the whole thing as one piece, split it up and print each part separately, then assemble the completed parts. Same as with the 132 podium, the numbers can be removed or printed as MMU or separately in different colors. https://www.printables.com/model/512481 1 Quote Link to comment Share on other sites More sharing options...
tsmsoccer Posted June 25, 2023 Report Share Posted June 25, 2023 Thanks for sharing Greg might have to give this one a go Charlie Quote Link to comment Share on other sites More sharing options...
Kevan Posted June 26, 2023 Report Share Posted June 26, 2023 That TEAM SLOT ESCORT RS 2000 MkII is a rare bird Quote Life is like a box of Slot cars... Link to comment Share on other sites More sharing options...
MrFlippant Posted June 26, 2023 Author Report Share Posted June 26, 2023 7 minutes ago, Kevan said: That TEAM SLOT ESCORT RS 2000 MkII is a rare bird Is it? I probably paid too much for it, but you know me... I had to have it. Quote Link to comment Share on other sites More sharing options...
Kevan Posted June 26, 2023 Report Share Posted June 26, 2023 You and your blue & yellows... Thankfully I don't have any infatuations like that...well apart from...ssshhhhhh say nowt 1 Quote Life is like a box of Slot cars... Link to comment Share on other sites More sharing options...
